Been facing an intermittent noise from the engine. Some points of observation on the noise-
When engine is warm, and engine is turned off there is a squeaky noise
After the engine is warmed and is idling, there is intermittent screaching noise
While off roading with windows rolled down, with the jerks the same squeaky noise can be replicated
While sudden acceleration or shifting in reverse quickly there is a clunky noise
Other than this there is no problem while driving.
This noise started slcoming around 10k kms, and now the vehicle has clocked 20k kms.
Got this issue checked at service center, they couldn’t find any issue, and mentioned if the noise become more frequent it will be easier to diagnose (even though it will possibly lead to a mahor issue at that point )
Anyone faced this kind of noise or sound from ther vehicles?
Your fan belt is either loose or become too hard with use. Get it tightened up and the noise should stop.
Also get your AC pulley checked. Sometimes the bearing inside it dries up and makes noise.
Does the sound occur when you press the accelerator on a cold start up. If it does then definiltely its the fan belt. How much have you driven till now…
I investigated the noise issue further, it is coming from the eshaust mainfold to the exhaust pipe coupling. The coupling has 2 springs along with bolts to absorb vibrations from engine, with some rusting on the pipe, springs and bolts it makes squeaking noise.
