Gearshift issue in manual
Hello folks
So recently got a issue in my manual jimny gearbox that it stucked and wasn’t shifting into any gears from which it is stucked and sometime take a lot of force to shift , clutch is new and working properly,
So I changed the gear oil and suddenly after that it worked properly for approx 600/700km but now again it got stucked and as I tried to check it myself by taking out the gear lever so found water near the linkage but when I drain the oil there was no water .
So is there anyone else facing the same issue . If yes it will be great full of him to tell how he got it solved .
Thank you in advance
Most likely the gear lever assembly needs to opened , cleaned, lubricated and installed again. Several people have faced this issue when doing water wading. The gear lever base has aball joint that get corroded if water accumulates there for too long.
Usually the gear level assembly needs to be replaced.
If you do water wading you need to thoroughly check differentials, transfer case, gearbox etc for any water ingress and replace the oil as soon as possible. The oil will turn cream color if water has entered.
Never go above 1 feet or standing water in the Jimny unless you have a differential breather kit. Even then the water level should remain below the gear lever base level. Water enters from the place where the gear lever is bolted to the floor of the Jimny.
have diff Breather and gear and transfer Breather installed
But also just cleaned the gear leaver area and put up everything back but still same issue
Hey man, since you’ve already cleaned out the shifter ball joint and you have all the breathers installed, you need to look a bit deeper. The fact that the gear oil change fixed it for about 600km before the stiffness came back is a massive clue.
Before you open anything else up, do this quick test to isolate the issue:
  1. Turn the engine completely OFF and try shifting through all the gears.
  2. Now, start the engine and try shifting into gears while idling.
If it shifts perfectly smooth when the engine is off, but jams up or gets super stiff only when the engine is RUNNING, your gearbox internals are actually fine. The issue is clutch drag. Even though the clutch is new, if it’s an aftermarket (AM) kit, the pressure plate fingers might not be releasing fully, or the mechanic forgot to replace/grease the pilot bearing inside the flywheel. A sticky or dry pilot bearing will physically force the gearbox input shaft to keep spinning with the engine, locking you out of gears.
If it’s stiff regardless of the engine being on or off, here is what’s happening on the ground:
The Shifter Tower / Striking Rod is binding
You found water near the linkage but not in the main oil drain. This means water got trapped in the upper shifter extension housing (the tower) but hasn’t fully dropped into the main gear case reservoir. Cleaning just the top ball joint isn’t enough. The water likely ran down onto the internal striking rod (selector rails) and the spring-loaded detent pins that lock the gears in place, causing deep rust or pitting. When you changed the gear oil, the fresh oil splashed up and temporarily lubricated these sticky rails, which is why it worked fine for 600km until the oil film wore off and the metal started binding again. You need to unbolt the shifter housing completely, look down at the actual selector rails, clean off the rust with a good penetrant, and pack it with heavy-duty marine grease.
:upside_down_face:
It’s highly likely a combination of aftermarket parts and installation error.
  • The Shifter Boot: Even though you have breathers, water still got into the linkage. When people install aftermarket gear/transfer breathers, they almost always have to mess around under the console and often accidentally tear or improperly seat the factory rubber shifter boot. When you go wading, water completely bypasses your breathers and pours straight through that compromised boot into the shifter base.
  • Kinked Breather Lines: Check the routing of your aftermarket breather hoses. If the line for the gearbox is kinked, pinched, or clogged, the transmission can’t vent. As you drive, heat builds up internal air pressure inside the casing, creating a pneumatic wall that physically fights against the shift rails when you try to change gears.
Do the Engine ON/OFF test first, check that rubber boot under the floor console for tears, and make sure your breather lines aren’t pinched. That should pin down exactly where it’s binding.
