Rattling Noise – Dashboard Removal
Hi,
I’m hearing a rattling or vibrating noise coming from the dashboard on the passenger side. When I hold the grab handle, the noise stops. The service center couldn’t find anything, so I’m wondering if anyone else has experienced this. Has anyone tried opening the dashboard or knows how to open it? Any help would be appreciated.
There are two bolts that hold the grab handle from the behind. They have to tighten those two bolts by going under the dashboard.
Thank you, that solved the problem. The bolt was tough to reach, and I had to use a flexible ratchet handle to get to it, but the rattling is gone now.
