Swivel Oil leak
Has anyone experienced swivel oil leak? I’d appreciate any advice on how to fix it.
Doesn’t look like a leak. It’s normal to have some amount of dampness on this area due to Frequent movement of the the joint. Unless you see a streak of oil or oil dripping out you are fine. Just get the area cleaned regularly so it’s easier to spot.
If you are still concerned you can ask the SC to check the seals and replace them.
As you suggested, I cleaned the area and drove 50 km. There are no signs of any leakage. Thank you for your help. I had noticed it at both joints after an off-road drive.
